3 members (NH46COE, Hotrod Lincoln, 1 invisible), 111 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#976203 10/03/2013 8:30 AM
54 3100. My brake lights are staying on after I turn the ignition off and the headlights are off.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
Check and see what's going on with your brake light switch.
The brake lights should work with the ignition or lights ON or OFF.
Do they go off when the ign is ON? If so, then they are probably wired wrong. Make sure that it is wired like the wiring diagram.
> 1954 Wiring Diagram
If they go off when the lights are ON, then there may be two problems ...
1) The brake lights may be wired to the tail light filament with the low level brightness; and the tail lights to the filament with the high brightness. The brake lights should be to the filament with the high brightness. The bright filament will mask the dimmer filament when they are both on.
2) There is a wiring or mechanical problem that is keeping the brake lights on all the time.
If they are on all the time, then check these ...
> The two wires to the switch may be reversed with the hot going to the lights instead of to the switch. Switch them to test.
> Make sure that the brake light switch is screwed tightly to the toe pan. Access the screws from the interior side of the pan. If it's loose, the switch will swing down and release the switch arm to the ON position. (Don't ask me how I know this)
> Make sure that the brake pedal arm return spring between the arm and the frame is pulling the pedal all the way back. (Don't ask me how I know this, either) Release the brake pedal slowly to test. If released with a thump, or while driving, it will move the pedal arm fully and turn off the brake lights. Replacement spring is available at most suppliers. Universal springs at FLAPs.
> Does the arm have a rubber bumper on it that bumps against the firewall when the pedal is released? I don't believe that it should have one. It will keep the arm from retracting all the way and keep the brake lights on. The clutch arm should have a bumper.
If those don't cure the problem, then remove the switch and test it with a multi meter or a test light. If it works, then the arm may need to be bent a little (?). If it doesn't work, then replace it.
- Lonnie
- Lonnie
My '54 3104
One other item to check is the adjustment nut on the pedal assembly, it will back off at the Master Cylinder and not allow enough travel for the switch to shut off.
I have had issues recently w the brake light switch. I think it's busted.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
I tried switching the wires to the switch but the brake lights still come on. The brake lights stay on 100% of the time
DJ __|__
--O-(_)-O--
'54 Chevy 3100
simple: you have a shorted brake light switch, replace it
Swapping wires on the switch proves nothing.
I swapped the Brake Light Switch last week, I didnt even notice that the lever completely broke off. No Wonder.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
