| | | Forums66 Topics128,014 Posts1,055,331 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i have a 1112353 distributor that i took off my old 216. will it work on my 54 235? my interchange manual says it should be a 1112388 dist and it doesn't even list a 1112353. it's an ac delco.
rolf
1963 c10 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes it will work, however the drive gear I believe may fail with the later type cam. At least check this out. I wouldn't use it as points may be more difficult to find than later type dist. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The issue is the camshafts... cast iron or steel. The steel will be much harder and will chew up cast iron gears. HERE IS A LINK TO ID THE CAM AND DIZZY | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | ok i found two distrubutors one is a 2304 the other a 2392 (for a 261) i'm going to take them apart and clean them up anything i should know before i start?
thanks rolf
1963 c10 | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | A rebuilt dist from Advance (Pn 30-1609) is $56+$10core. Includes a set of points and condenser... all you need is the vacuum advance or dist clamp.
They do not come with a grease cup or data plate... other than that for $60 (less if you get the coupons) I would just buy a new one and not worry about gears or worn parts. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 |
1963 c10 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check napa also I purchased one from there for my 54 235. It came with vac advanced and the grease cup ...pic... If your new one comes with an o ring as in that pic, remove it. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | Thanks guys i'm gonna take it apart and clean it. it needs the gear pin replaced
rolf
1963 c10 | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Check the bushings/shaft for play. I don't know if there are any rebuild kits out there... but springs do wear out and the weight holes can become worn if not lubed... all minor issues.... but that's what causes poor performance.. your timing not being in, well, time. | | |
