Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
I have an outer front wheel bearing that my mechanic can't find a cross reference for. The number on it is Hyatt A11020(Q) and the outer piece is 11080 Z. The inside diameter is 0.937" and the outside diameter is 2.345". I know a lot of you are working on 2-tons, so these must be available from somewhere. I would be grateful for any help in tracking one down.
3B Offline
Hy Ed Hotaling, I think the bearing that your looking for is a KA11020Z, the components of that bearing are 15574A and 15522A Bower, the Hyatt numbers are getting harder and harder to trace, I could not find any reference to them, hope that helps.
Thanks, 3B.
I just went through that with a '48 2 ton,
Barrel rollers are about as extinct as a Dodo bird.
I have an very good bearing supplier and his search turned up 1 source for current supply. Prices were between $350 and $500 a bearing.
I did find a listing for Chinese new parts but wouldn't chance that.
I searched Ebay, Craigs list etc. and finally found NOS for everything.
