| | | Forums66 Topics128,274 Posts1,058,425 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I have an outer front wheel bearing that my mechanic can't find a cross reference for. The number on it is Hyatt A11020(Q) and the outer piece is 11080 Z. The inside diameter is 0.937" and the outside diameter is 2.345". I know a lot of you are working on 2-tons, so these must be available from somewhere. I would be grateful for any help in tracking one down. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Ed Hotaling, I think the bearing that your looking for is a KA11020Z, the components of that bearing are 15574A and 15522A Bower, the Hyatt numbers are getting harder and harder to trace, I could not find any reference to them, hope that helps. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I just went through that with a '48 2 ton, Barrel rollers are about as extinct as a Dodo bird.
I have an very good bearing supplier and his search turned up 1 source for current supply. Prices were between $350 and $500 a bearing.
I did find a listing for Chinese new parts but wouldn't chance that.
I searched Ebay, Craigs list etc. and finally found NOS for everything. | | |
