Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 146 guests, and 3 robots.
Topics128,290
Posts1,058,565
Members48,492
I have a 1946 3100 3/4 ton pick up.
I am attempting to install the rear flex brake line that connects the rear axel 'T' to the ridgid line that runs forward. I purchased this from Chev's of the 40's, p/n 476719. I find that it will connect, but only barely reach. If (when) the rear axel drops, I fear that the line may not survive. The axel and frame mounts at either do not appear to be bent. The flex line that I received is 15.25" long, from hex "nut" end to hex "nut" end. AM I missing something, wrong part, what?
Bob
BobS46
I ran into the same problem with my 1 Ton. However I was making up all new steel lines so I just moved the bracket a bit closer to the rearend and it worked out fine. You definitely want lots of room for the flex line to move.
1951 1 Ton Completed
Thanks. But my bracket is riveted to the frame - I think I will try to find a longer line. Surely they come in longer lengths for other applications.
BobS46
got a NAPA nearby? take the short one in and get them to come up with the same thread ends in a longer hose
I don't know if the fittings are the same, I just got one for my 1961 3/4 ton it is 17 5/8. at autozone.
Thanks all. I just got one from NAPA - about 18" long.
BobS46
