| | | Forums66 Topics128,290 Posts1,058,559 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I have a 1946 3100 3/4 ton pick up.
I am attempting to install the rear flex brake line that connects the rear axel 'T' to the ridgid line that runs forward. I purchased this from Chev's of the 40's, p/n 476719. I find that it will connect, but only barely reach. If (when) the rear axel drops, I fear that the line may not survive. The axel and frame mounts at either do not appear to be bent. The flex line that I received is 15.25" long, from hex "nut" end to hex "nut" end. AM I missing something, wrong part, what?
Bob
BobS46
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I ran into the same problem with my 1 Ton. However I was making up all new steel lines so I just moved the bracket a bit closer to the rearend and it worked out fine. You definitely want lots of room for the flex line to move. | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks. But my bracket is riveted to the frame - I think I will try to find a longer line. Surely they come in longer lengths for other applications.
BobS46
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | got a NAPA nearby? take the short one in and get them to come up with the same thread ends in a longer hose
Bill | | | | | Joined: Oct 2012 Posts: 12 New Guy | | New Guy Joined: Oct 2012 Posts: 12 | I don't know if the fittings are the same, I just got one for my 1961 3/4 ton it is 17 5/8. at autozone. | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks all. I just got one from NAPA - about 18" long.
BobS46
