Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, CuzzFuzz), 27 guests, and 0 robots.
Topics128,003
Posts1,055,245
Members48,418
#975001 09/28/2013 11:56 AM
I found a slider switch under the dash of my 1941 chevy truck this morning. It is under the throttle and choke knobs. I found a switch on line that shows it as a dimmer switch. I also have a standard dimmer switch on the floor. What is it?
eyell #975009 09/28/2013 1:08 PM
dash light switch, one position is dash lights, one is map light, 3rd is off
Flxible #975024 09/28/2013 2:23 PM
thanks. I'll have to test it tonight to see if it works.
eyell #975188 09/29/2013 6:56 AM
dash lights on all the time with headlight switch on. however, they seem dim to me. Is this because they are 6 volt. Also, where is the other light socket supposed to be? Thanks in advance.
eyell #975194 09/29/2013 8:20 AM
location: http://chevy.oldcarmanualproject.com/chevyowner/42tom07.htm
have you looked under the dash?
do you know if all the dash bulbs are there and working?
is the slide switch wired up?
do you have a wiring diagram?
what condition is the wiring in?
Flxible #975219 09/29/2013 11:18 AM
wiring is new. THere is a wire labled power to the switch. No other wires that i can tell will have to do more investigation. Will get meter out and bend my back to determine what is miswired or not wired.
