1 members (TUTS 59),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | I found a slider switch under the dash of my 1941 chevy truck this morning. It is under the throttle and choke knobs. I found a switch on line that shows it as a dimmer switch. I also have a standard dimmer switch on the floor. What is it? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dash light switch, one position is dash lights, one is map light, 3rd is off Bill | | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | thanks. I'll have to test it tonight to see if it works. | | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | dash lights on all the time with headlight switch on. however, they seem dim to me. Is this because they are 6 volt. Also, where is the other light socket supposed to be? Thanks in advance. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | location: http://chevy.oldcarmanualproject.com/chevyowner/42tom07.htmhave you looked under the dash? do you know if all the dash bulbs are there and working? is the slide switch wired up? do you have a wiring diagram? what condition is the wiring in? Bill | | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | wiring is new. THere is a wire labled power to the switch. No other wires that i can tell will have to do more investigation. Will get meter out and bend my back to determine what is miswired or not wired. | | |
