| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I have '42 1/2 ton and just put a '54 235 engine in it. My problem is the original '42 clutch/brake pedal assembly mounts right up to the motor but the throw out arm doesn't line up. I didn't have the original throw out arm so bought one over the net for a '54. The arm is too close to the clutch pedal (no room for the linkage rod) and the distance needed to disengage the clutch doesn't seem to be enough. Is there a difference in throw out arms and what do I need to do to correct the problem? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are different and did change over the years. I would post an ad in Swap Meet to see if someone had them, they also show up on eBay with some regularity. | | |
