| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | I was just trying to figure out how I should wire the following things up in my truck: radio, heater, wipers. I'm not sure where I should get the power from for all of these items. I was wondering if I could run a fuse block off the ignition and then run all of these things to the fuse block. Any suggestions would be helpful, thanks guys! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | A couple questions are you trying to stay original? Do you have the rare electric wiper set-up or are they still vacuum? If original they will come off an existing connection (ignition or headlight switch most likely). If you have just the heater and radio you really don't need an additional panel. A bit more information will help people answer your questions. | | | | | Joined: Apr 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 127 | Would like to stay original if I can I thought a fuse panel would be nice though. I have vacuum wipers and the original radio and heater. This has been a 8 year project and I did not get good pics how they were wired up so of course I cant remember. So how ever they were wired out of the factory would be fine. Thanks again | | |
