7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I just found out the VIN on the title does not match the VIN thats in on the cab. What other locations can I look to see if the VIN matches? | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | FP, Back in the day, the used the number on the block, just behind the distributor. Where in Spring are you? I'm off Louetta and Champions. Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I just rebuilt the engine and replaced the block. I don't think the vin will match.
I will be at the Hot Rod show in Old Town Spring this weekend. I'm off of Rayford Sawdust | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | Around 1955 GM started adding the long VIN numbers to the frames and cabs. Before that, the engine serial number was used. With out original engine, you are at the mercy of the DMV and Highway Patrol inspection center. The numbers on the cab indicate build number, size, and factory location, nothing to do with the VIN, unless someone at one time wrote the build number in for the VIN, all the states didn't work the same.
Take the original block with you if you still have it.
Joe | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I just had the engine block replaced. I believe it says LAS525272
According to some websites it means it's a 53 truck made in Missouri. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | The engine serial number is different to the vehicle serial number. I believe that your engine is a 1953 passenger car engine. (Tim Lederman is the engine number expert. He may give better information.) L = 1953 Model Year A = Passenger Car S = Engine built at Tonawanda, NY engine plant with RPO 313 and RPO 324 525272 (minus 1,001) = the 52,4274th engine built at the plant RPO 313 = Powerglide RPO 324 = Hydrolic Steering (power steering) The 1953 passenger car Powerglide engine was different to 1953 truck engines: 235.5 cu in, instead of 216 cu in in 3100 truck Full pressure lubrication vs spray oiler in 3100 truck Hydrolic lifters instead of solid lifters in 3100 truck Advertised max engine performance: GBHP = 115 @ 3600 RPM NBHP = 108 @ 3600 RPM G Torque = 200 ft lb @ 2000 RPM N Torque = 196.5 ft lb @ 1000 RPM I believe that the valve cover was held to the head by two acorn nuts on top. The 1954 valve cover had four slots on top and was held to the head by four screws. Documentation: 1953 Passenger Car serial numbers http://chevy.oldcarmanualproject.com/chevyresto/53009.htm1953 Passenger Car RPO http://chevy.oldcarmanualproject.com/chevyresto/53044.htm1953 Powerglide Automatic Transmission Supplement (blank page), see "next pages" http://chevy.oldcarmanualproject.com/chevyresto/53045.htmMore engine number on pdf p 12 of 123 of Truck Vehicle Information Kit at GM Heritage Ctr. http://www.gmheritagecenter.com/doc...hevrolet-Trucks/1953-Chevrolet-Truck.pdfSerial number locations on 1954 trucks: http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm000.htmlhttp://chevy.oldcarmanualproject.com/chevyresto/54057.htm- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you still have your original block and that number is indeed the one on your title, keep it. That may make the process easier getting it re-titled. Every state has a process to resolve your issue, you just need to call them to find out what hoops you need to jump through.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Thank you for that excellent break down!
I am in Texas, I will need a bill of sale from the shop that replaced the block stating so. Then I have to go to the county tax office and fill out a change title vin form.
Where is the VIN on the frame located? It most likely won't match either of the others but I would like to know. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was no vin on a 54 frame, that didn't start until after the 55 2nd series, and then it was put on the top frame rail near the steering box, and it matched the door tag vehicle ID number
Bill | | |
