4 members (sron48, BC59, 2 invisible), 133 guests, and 5 robots.
Topics128,086
Posts1,056,099
Members48,434
#974123 09/24/2013 5:38 PM
I was in the process of removing the manifold on my 46 3800 to fix an exhaust leak. Everything was going remarkably well, even the bolts were coming out nicely when..."tink" and the rear ear fell into my hand...
So now I'm in need of a manifold.
The casting number on the intake looked like 3836160,
Googling that brings up a 235 water pump. One or more of the 3's might be an 8 but the 6160 is pretty certain.
The exhaust side has no numbers I can identify due to corrosion.
The exhaust outlet in straight down and the carb pad is for the smaller 216 carb.
Block number if it helps is 3835253.
Any help would be appreciated and if anyone has one that would work Please let me know.
I believe that can be welded. Make some calls to shops that weld cast iron.
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
3835253 : 1948-489 216
I think the intake/exhaust manifolds that year were the same for 216/235?
Didn't some of the 216 engines have the D shaped exhaust ports
and then later the square or rectangular ones? When was the change over?
I could get the ear welded but figured for the cost of welding I might find another manifold altogether. Also even after extensive soaking in pb blaster all 4 bolts broke upon trying to split the intake and exhaust.
A torch might help get them out but I'll still have the crack to deal with.
I'm pretty sure all the early 216 manifolds were similar but the casting number has me thrown off.
Thanks for all the responses..
Post in the parts wanted section of the forum.
Could get lucky, include your cast number in request to make sure you get the correct exhaust flange.
Will do, It does have the horn bracket cast into it as well.
Thanks..
