3 members (Lostbuthaulinass, Otto Skorzeny, Nick in Manitou), 81 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#973713 09/22/2013 10:47 PM
Has anyone had success drilling out the frame holes for the new Lower A-Arm U-bolts on a 65 c10? According to LMC, the holes have to be drilled to accept the 9/16 u-bolts but the lower hole seem aweful close the the frame curve already. I'm afraid the nut will bind before tightening up...?
Thank you,
Tim
timmc #973763 09/23/2013 8:54 AM
It is tight, but it will work, I've done it on many.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Good deal. I'm gonna give it a try tonite. I will be using a heavy duty drill w/VS and handle! Can't afford any broken bones! Thank you for the reply Sir!
Tim
timmc #973922 09/23/2013 8:56 PM
It worked fine. I have to admit, when I installed the lower shaft I did not pay attention to the dimple. I was lucky to have installed both in the correct direction - toward the front of the arm!
timmc #973930 09/23/2013 9:15 PM
Could you elaborate on the dimple comment? I am planning to rebuild the front end on my '65 and was hoping to learn from your experiences.
timmc #973942 09/23/2013 9:58 PM
HRJ and Tim,
I take pics of everything. pix This may help. I remember stumbling across the "dimple and bump" while reading my FSM looking for torque specs. It must line up or it will not be flush. Make sure the shaft is about mid-way in the rotation before you line up the bump and dimple.
These pics are all from the PS assembly.
Bump 1
Bump 2
Dimple 1
Dimple 2
Bolted up it will sit flush in the saddle.
Lugnutz #973944 09/23/2013 10:14 PM
Lugnutz You Be Da Man! Thanks, that's information I can use. thumbs_up
So let me ask some more questions. This winter's to-do-list for my '65 C10 includes a front suspension and steering rebuild and a dual master cylinder install. The drum brakes and 6 lug hubs however are staying. Contemplating a front sway bar addition also.
Any suggestions regarding rebuilding the oem front end, such as Moog vs. ???? Go with parts from my local NAPA or buy a kit from our host? I really want to avoid foreign made parts.
The shafts have a dimple that needs to line up with the rivet/dow pin that comes thru the front-side lower a-arm saddle. The pin will set into the dimple. Be sure the dimple end of the shaft is toward the front side of the A-arm when replacing it.
Tim
timmc #973947 09/23/2013 10:17 PM
Hey lookyie there.. Jay comes thru again! Great pics!
Thank you Jay.
timmc #973950 09/23/2013 10:24 PM
Shot of the new 9/16" u-bolts installed after drilling the frame.
Installed
New vs Old size difference
Lugnutz #973952 09/23/2013 10:26 PM
Jay - I'm learning from your site as I go! BTW, do you have the torque specs handy on the bolts?
Tim
Me? Offer suggestions? I'm totally new to this hobby! I buy my parts at Autozone, NAPA, Walmart, etc.
Tim
Tim and HRJ,
Page 15-2 in the 1963 FSM says
LCA Shaft U bolt
CP10 = 30 - 40 lb-ft
UCA Shaft
CP10 = 40 - 55 lb-ft
timmc #973965 09/23/2013 11:24 PM
Lugnutz,
I can't wait to see the finished product! Wow! what a great job so far.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
timmc #974196 09/24/2013 8:48 PM
Well, I busted a lower ball joint boot tonite getting in a hurry. Any suggestions where to buy the boot only?
Tim
timmc #974207 09/24/2013 9:32 PM
Tim
No suggestions other than the local parts store or Rock Auto. I guess I'm not much help. Did the boot get pinched?
timmc #974240 09/24/2013 10:46 PM
I was using a piece of PVC pipe to tap the boot ring down over the shoulder. The first one went well; the second pealed the rubber loose from the ring. I'll post any finding of a replacement boot. These are new joints; I would hate to buy another one!
Tim
timmc #974244 09/24/2013 11:02 PM
Moog lower ball joint on Rock Auto is only $8.03 plus shipping. Autozone is $13 plus tax. At least it's not something like a fender! Yikes!
timmc #974628 09/26/2013 7:11 PM
I purchased a new ball joint from Autozone and used the boot that come with it. Now I have all new ball joints!
Now it's time to collapse the front springs to get them into place.
