| | | Forums66 Topics128,005 Posts1,055,255 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | is there much difference between .23 and.25 wire for welding thin metal? | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | never used .25 always used .23 for welding sheet metal | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | Answer, YES.
Although it does not sound like much, using the smaller wire allows you to use less amps, less amps means less heat, less heat means less distortion to your metal panels.
Look at your suggested settings placard on your machine or in the manual and you will see a lower "heat" setting.
Unless you are great at bodywork AND love banging metal, go for the thinner wire.
Mikey | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used spool arc easy grind ...link... It was easy to work with for a novice like me. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | From my experience, HF sells .23 wire and when you go to your Lincoln dealer they sell .25. The Lincoln guy says the knockoff wire is interchangeable but they don't recommend it. Of course they would say that. I use the Lincoln stuff but I have tried the .23. If there is a difference, I cant see it. The wire speed is all the difference there is. If you up the speed about a hair when using .23, you now have .25. HF IS cheaper, but doing some research on the makeup of the wire itself, I prefer to go with alloys that Lincoln recommends.
There is more to this than that, I like the Lincoln company model for taking care of its employees and the philosophy of the company. Its ALL a matter of personal preference. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I don't think anyone even makes 1/4 inch welding wire for a mig system. Maybe ya all mean .023, it makes a huge difference which side the decimal point is of that zero.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I was trying to be PERIOD correct! LOL. | | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | learning how to weld on my own, welded few patches on vehicles... used .25, once in awhile would burn through, so thought I try .23 for the heck of it, thanks for info guys... | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | yeah, I don't think you will be able to tell the difference, but maybe you are more acutely aware of things than I am. Its a lot of fun and leads to lots of things you thought you would never do! LOL. | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | All welding supply houses have .023 and .025 as well as others.
DADS50 has a great point, get the easy grind. Not only does grinding go faster but you will generate less heat and again less distortion to your panels.
My Lincoln welder accepts both.
Check your manual, you will need to change the tip as well,
Good luck. Mikey | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Odd but I buy my wire from the local Airgas store it's actually cheaper then HF by a buck or 2 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Harbor Freight 10 LB .023 is $28-%20= $22.40 and a free flash light. I tried the stuff called "20 gauge", it works good on thin. Not .020 gauge wire, the name is "20 gauge" by Harris. Haven't seen it anywhere for a few years. Didn't catch on.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | My Lincoln SP275 (an older model) accepts both as well, but without changing the tip. If you go to .030, you change the tip. If you change from .023 to .025, since argueably, the diameter is just a matter of the Chinese spending less on wire due to cheating on the diameter, thus charging less, the tip is the same.
Its like I said. Put the .023 cheaper stuff on, turn the speed control about .002 higher, and now you have .025! I made the decision awhile back to just stick with Lincoln wire which is .025. I get the larger roll and then I am good for a few months! The welding supply in Wichita, KS tells me Lincoln doesn't make ANY diameter sizes for mig other than .025 and .030 for my particular welder. If they are wrong, I am wrong too. It's mute anyway, because we are all having a blast making new stuff, creating new jigs, creations, with what we are comfortable with. | | |
