Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#973590 09/22/2013 1:53 PM
is there much difference between .23 and.25 wire for welding thin metal?
696969 #973602 09/22/2013 3:40 PM
never used .25 always used .23 for welding sheet metal
696969 #973603 09/22/2013 3:41 PM
Answer, YES.
Although it does not sound like much, using the smaller wire allows you to use less amps, less amps means less heat, less heat means less distortion to your metal panels.
Look at your suggested settings placard on your machine or in the manual and you will see a lower "heat" setting.
Unless you are great at bodywork AND love banging metal, go for the thinner wire.
Mikey
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
696969 #973621 09/22/2013 5:45 PM
I used spool arc easy grind
...link...
It was easy to work with for a novice like me.
696969 #973629 09/22/2013 6:57 PM
Gas Pumper
Gas Pumper
From my experience, HF sells .23 wire and when you go to your Lincoln dealer they sell .25. The Lincoln guy says the knockoff wire is interchangeable but they don't recommend it. Of course they would say that. I use the Lincoln stuff but I have tried the .23. If there is a difference, I cant see it. The wire speed is all the difference there is. If you up the speed about a hair when using .23, you now have .25. HF IS cheaper, but doing some research on the makeup of the wire itself, I prefer to go with alloys that Lincoln recommends.
There is more to this than that, I like the Lincoln company model for taking care of its employees and the philosophy of the company. Its ALL a matter of personal preference.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
696969 #973650 09/22/2013 8:00 PM
I don't think anyone even makes 1/4 inch welding wire for a mig system. Maybe ya all mean .023, it makes a huge difference which side the decimal point is of that zero.
696969 #973651 09/22/2013 8:01 PM
Gas Pumper
Gas Pumper
I was trying to be PERIOD correct! LOL.
Deve
The Think Tank
696969 #973653 09/22/2013 8:08 PM
learning how to weld on my own, welded few patches on vehicles... used .25, once in awhile would burn through, so thought I try .23 for the heck of it, thanks for info guys...
696969 #973695 09/22/2013 10:11 PM
Gas Pumper
Gas Pumper
yeah, I don't think you will be able to tell the difference, but maybe you are more acutely aware of things than I am. Its a lot of fun and leads to lots of things you thought you would never do! LOL.
Deve
The Think Tank
696969 #973770 09/23/2013 9:37 AM
All welding supply houses have .023 and .025 as well as others.
DADS50 has a great point, get the easy grind. Not only does grinding go faster but you will generate less heat and again less distortion to your panels.
My Lincoln welder accepts both.
Check your manual, you will need to change the tip as well,
Good luck.
Mikey
696969 #973970 09/24/2013 12:42 AM
Odd but I buy my wire from the local Airgas store it's actually cheaper then HF by a buck or 2
696969 #973986 09/24/2013 3:09 AM
Sir Searchalot
Sir Searchalot
Harbor Freight 10 LB .023 is $28-%20= $22.40 and a free flash light. I tried the stuff called "20 gauge", it works good on thin. Not .020 gauge wire, the name is "20 gauge" by Harris. Haven't seen it anywhere for a few years. Didn't catch on.
696969 #974192 09/24/2013 8:35 PM
Gas Pumper
Gas Pumper
My Lincoln SP275 (an older model) accepts both as well, but without changing the tip. If you go to .030, you change the tip. If you change from .023 to .025, since argueably, the diameter is just a matter of the Chinese spending less on wire due to cheating on the diameter, thus charging less, the tip is the same.
Its like I said. Put the .023 cheaper stuff on, turn the speed control about .002 higher, and now you have .025! I made the decision awhile back to just stick with Lincoln wire which is .025. I get the larger roll and then I am good for a few months! The welding supply in Wichita, KS tells me Lincoln doesn't make ANY diameter sizes for mig other than .025 and .030 for my particular welder. If they are wrong, I am wrong too. It's mute anyway, because we are all having a blast making new stuff, creating new jigs, creations, with what we are comfortable with.
Deve
The Think Tank
