0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#973488 09/21/2013 11:56 PM
I have the rust problem at the bottom of the doors.
My question is, is the bottom edge of the door skin welded to the inner door or is it just folded over?
Door skin is just fine the inner door rusted from the out side in under the wind lace attachment.
It's folded and spot welded.
Give me ambiguity
or give me something else
Oh joy a spot weld hunt
Know what you mean. Once you remove the paint, you should feel a little dimple which is probably the spot weld. I did this for a couple of patch panels. Dreading doing it to the bed to remove the spot welded angle pieces on the sides.
Dennis
40 Chevy 1/2 ton
The skin on my '52 doors were not spot welded. Once I ground through the fold, the left over piece on the inside of the door came off easily. But, it is possible that was a symptom of the rust. I would most concerned about welding in the door bottom skin patch panel and not warping the door skin. When that happens, good luck.
