0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | I have the rust problem at the bottom of the doors. My question is, is the bottom edge of the door skin welded to the inner door or is it just folded over? Door skin is just fine the inner door rusted from the out side in under the wind lace attachment. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It's folded and spot welded.
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Know what you mean. Once you remove the paint, you should feel a little dimple which is probably the spot weld. I did this for a couple of patch panels. Dreading doing it to the bed to remove the spot welded angle pieces on the sides.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The skin on my '52 doors were not spot welded. Once I ground through the fold, the left over piece on the inside of the door came off easily. But, it is possible that was a symptom of the rust. I would most concerned about welding in the door bottom skin patch panel and not warping the door skin. When that happens, good luck. | | |
