5 members (Gib70, 3B, MickeyP, Jon G, 1 invisible),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Does anybody still sell a rebuild kit for the water pumps used on the 48-54 Chevy trucks??
John | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are available, check eBay for NOS and Hemmings for kits. I believe Kanter Products advertises them there. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've found quite a few advertising the newer style 55-62 ones. John | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy, if anyone really knows of a source I'd like to hear about it. I looked real hard several years back and like the Trico wiper parts, couldn't find anyone that was still selling them.
Back in the day, that be in the early 60's when I was a Chevy parts man you could buy the bearing, which is all it is, a double row sealed bearing that you simply press the old one out and the new one in and your set to go. Did a few of them for my self back then.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bearing it self will be good in a 50 or 60 year old NOS kit but I wouldn't count on the seal still holding water or the grease not being dried out and those are as I mentioned earlier, sealed bearings. Someone is making the bearings and seals cuz they are still selling rebuilt and new water pumps for our trucks. Finding the source for new fresh parts is the kicker.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | That is what I wondered whether NOS would be any good now or not. Probably a 50/50 prop....
John | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | NOS is a great find when it's a metal component but rubber, leather, plastic, paper, grease just don't hold up over the years. Most parts that had wiring would be a problem as would the seals that were mentioned above.
Denny G
