8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Hoping someone might be able to give me some direction. I'm trying to replace my front drums on the 64 k10 pickup. I'm having a hard time identifying a vendor that carries them. If I can find the GM part # my Napa store can probably order them. Anyone come across the part number? Thanks john
1964 K10 Fleetside Pickup Truck | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if i can remember rightly, but i may be out to lunch. try a rear drum on ron | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There may be a parts listing book here for finding the original numbers.... and possibly other stuff you'll enjoy. Worth the look though even if they don't have your model year. http://chevy.oldcarmanualproject.com/...and as padresag mentioned. Some trucks the DRUM is the same front and read. EDIT: Advance Auto Parts has a REAR one listed for $59.29 part #BD60002. I didn't find a listing for the "Front" so maybe, just maybe they are the same and if so you'll use your front hub with it. Good luck. http://shop.advanceautoparts.com/we...eIdSearch=502284&searchedFrom=headerThey list others that may fit for less money. Check at the store.
| | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Thanks for the information. I got the rear drums at Napa and will try them on the front.
Is there anything I need to do other than clean the new drums with brake cleaner before I put them on?
My old ones needed resurfacing and it was just a bit more to get new ones.
Thanks John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | don't do anything to it before you try it in case I was full of poop and they don't work. not as difficult to take them back then ron | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | John, while I'm sure very few people have trouble with new rotors or drums one of the local shops here TURN EVERY NEW drum or rotor when doing a complete brake job. It may be just a SKIM cut but they do it....... I was skeptical until, as a delivery driver for Advance Auto, I seen first hand how some NEW ones are simply just not "true". But, as Ron says, do nothing until you know they fit! If good squirt them off good with Brake Kleen and your in business. (I guess I'm lucky. The same shop I mentioned turns my rotors or drums for $5 each) I guess its good be friends with some folks  | | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | The rear drums fit the front I'm ended up putting them on the rears and ordered a set for the front. There is a difference already. Thanks for the info.
