3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#97305 09/22/2006 9:01 PM
Riding in the Passing Lane
I bought new exterior door locks, along with the cylinder for the Ignition Switch, so that they would all be keyed alike.
Door locks are already in and working. smile
I'm not sure how to go about removing the old cylinder so I can add the new one.
It's a '67 Chevy PU.
What do I need to do?
Thanks!
~ davey
1967 Chevrolet 1/2-Ton Pickup
I'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.
I've forgotten more than I ever knew. Okay, where did I put it?
A man can never have enough tools
#97306 09/22/2006 9:03 PM
Ex Hall Monitor
Ex Hall Monitor
Don't know about a 67 but my 38 cylinder has a tiny hole in it. A paperclip end stuck in the hole allows the cylinder to come out.
#97307 09/22/2006 10:08 PM
Tiny is right. Turn the switch to the acessory position. Insert a paper clip or old choke cable in the hole. Turn it a little bit more ccw. It "should" come out now. Put the new one back in starting at the same position.
1972 Chevy c10 Cheyenne Super
#97308 09/22/2006 10:58 PM
Thanks a lot guys. I saw the hole, and figured it was something like that.
At this point in time, I just don't wanna mess anything up. Thought I'd ask for advice.
I'll go try that while I'm waiting on my pizza.
~ davey
#97309 09/22/2006 11:06 PM
That didn't take long. Maybe one minute?
Wrenchbender. It worked just like you said. I had to turn it a bit CCW to get it to release. The new one popped right in, and the truck cranked up without a hitch.
Now I have "one" key that will crank the truck and lock the doors. I couldn't even lock the doors before.
Finally, something that works!!!!!!
You guys don't know how much I appreciate your help! grin grin grin
Thanks a half-ton!
~ davey
