| | | Forums66 Topics128,188 Posts1,057,218 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | With colder weather approaching and my 49 3100 improving with any and all repairs & mods I do to it, it is time to get the heating system working. The truck has a recirculating air type heater, not the fresh air type, and when I would apply voltage to it it would just arc & spark, no fan movement at all. In takeing it out and apart the coil drained quite a bit of anti freeze out so this motivated me to dig deeper with the thought that the core may be good so lets see whats going on inside. The motor was bound up tight and would barely move even with the help of a pr of channell locks. But thankfully these old motors were built to be disassembled. Upon disassembly the insides looked good, the brushes looked to have plenty of life left, so I polished up the shafts where they go into the brass bushings at each end and dabbed a little bit of grease in them. I also used some emery cloth and shined up the commutator & brushs. Put it back together and the the moter spun easily by hand. I then applied 6v to it and she spun nice and smoothly with little noise  So I cleaned the rest of the heater up, blew decades of dirt,dust and whatever else out of the core, put it back together, reinstalled it and will be picking up approx 6' of 5/8" heater hose for a heat test tonight. Hopefully the core is still good. Bottom line, these old trucks and their parts were built back in the day when everything was still serviceable so before you throw something out, take it apart and clean it up some, it may be very worth your while. Dave | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Dave,
Good words of wisdom.
Just for fun, I took an old starter that had been laying unprotected in the bed of a truck for decades to see if I could bring it back to life. The part was rusted badly and nothing would rotate. I first dunked the starter in my electrolysis bucket for a day or two and things loosened up enough to enable spinning the shaft and disassembly of the case. A little sanding and greasing, and the darn thing worked! Granted the wire insulation and other parts were unsafe for true service, but what looked like scrap metal "may" be brought back to life. How cool is that!
Paul | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes those motors cam be disassembled and brought back to life as long as the coils aren't burned out. I've gotten the brushes from my local electric motor rebuilder, he may have to order them for you. Click next for a few more pix of the rebuild: http://www.pbase.com/dennygraham/image/114154836It would be a good idea to check that core before reassembly. I made up an adaptor to leak check the core and Ranco valve but you don't have to get that fancy, a tire pump would work also. Just don't put more than 7lb. pressure on the core or you will bend the tubes, they taint made to take any more pressure than that. http://www.pbase.com/dennygraham/image/113977784 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used two tire valves, a hand pump and a tire gauge to check mine. I also dunked it in a tub of water. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As you can see Fred, I just had to get fancy and make up a fixture for the radiator tester kit I had on the shelf. I liked it cus I could monitor and control the pressure very close. As I said, I was warned by an old radiator repair guy that had been in the business since the 60's, we were old school buddies as a matter of fact. He's the one that told me not to go over 7 lb. or I'd screw up the tubes.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Great input, I'm sure theres more than just me that appreciates and soaks up all this BTDT knowledge. Update. I have heat & partial defrost!  Atleast I had heat tonight  I only ran the engine for approx 20 minutes but in that time the heat ran me out of the cab. The rheostat/switch is bad so I had to run it hot-wired full blast. The core didn't leak in this test so it's not conclusive that it'll hold up under prolonged use, so I'll be monitorin it closely. I have the manual water valve and it didn't leak when openned up for heat during the test either, so, so far so good Parts needed to get it back into service is a new switch & defrost duct hose. In studying the cutouts in the firewall and Denny's pics, I can now see how the fresh air heater mounts. This basic recirc type heater I have has probably been on the truck since new so I'll run it until it breaks. It doesn't have a separate control for defrost, you get both heat and defrost once you turn the coolant valve on and the fan switch on. basic but it'll do for now. I can see a fresh air heater w/an electric coolant valve one day perhaps  Dave | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My recirculating heater has a knob that allows me to switch from floor heat to defrost. There is a little flapper inside that directs the flow. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | After looking at the pic of the recirc heater, my heater must be an off brand type installed by the dealer. Its about as basic as it gets. Heres some pics of the heater and switch that was in it. Heater w/defrost output showing Heater front view Switch | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Volfandt - Arvin was an aftermarket brand in the day, most likely installed by an owner .... Arvin also made domestic portable heaters, and I believe they still do Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Correct switch for that type of heater, Arvin heaters came I several styles and trims. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Got the new fan switch and ductwork in and got them installed. I wired in a 20 amp fuse for the new switch/fan circuit and gave it a test. I like that the switch illuminates when on and that the intensity varies with the fan speed. The defrosters work but even at high fan speed theres not a whole lot of air movement through them. I could possible block off some of the bottom heater outlet slots to get alittle more air flow out of the defrosters but I'll wait and see how it all works as is 1st.
I've been studying up on the delux air flow heaters and I really like their ability of opening/closeing coolant flow to the heater core by a control inside the cab. I may be looking into adapting that valve into my present setup. Presently I have to pop the hood and manually open/close the coolant valve thats mounted on the water pump. Dave | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dave, you can get an inline, cable controlled shutoff valve from your FLAPS. They were very common back in the day and are still available today. You can regulate the water flow with them also. http://www.autozone.com/autozone/pa.../N-91sh0?itemIdentifier=142802_148102_0_Denny Graham Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would replace that 20 amp fuse with maybe a 14 amp. The fuse is there to protect the wiring and I think 20 amps is a bit high. | | |
