1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#97270 09/21/2006 12:17 AM
I have a 61 1/2 ton that was changed for a generator to an alternator before I purchased it. Now I am having trouble with the external regulator. I have a newer alternator from an 81 chevy. Is changing from an external regulator to an alternator with an internal regulator difficult? I know hardly anything about electrical work so please keep it simple. :confused:
#97271 09/21/2006 12:57 AM
It's really not hard to do. Get rid of the old regulator, and the 3 or 4 wires that are with it. Run a 10# gauge wire from the starter sol. post where the + battery cable is hooked up... up to the battery post on the new alt. There should be a flat 2 wire plug on the alt, with a#1 and a #2 mark buy it, Hook up the #2 wire to the same post on the back of the alt. that you put that heavy wire from the starter on. The #1 wire should go to the acc. side fo your ign. switch. Thats it.If you have any questions, call me at 319-752-1036 ,Larry
#97272 09/21/2006 1:32 AM
Sounds easy to do. My only question would be how would #1 wire excite the alternator if the key switch wasn't turned to 'accessory'. :confused:
Stuart
#97273 09/21/2006 1:47 AM
61Apache,
I've found a website that has great electrical tech tips. Its called: http://www.madelectrical.com/electrical-tech.shtml
It has good overall reading, but the article called CHEVY Main Electrical Power System is a must read for your situation. grin
Best of luck,
Dave
#97274 09/21/2006 2:24 AM
Stuart, Stuart, Stuart-
The accessory position is also enabled in the run position, but not conversely. Putting the wire on the accessory position makes sure that the engine doesn't run on from alternator power when you switch it off.
#97275 09/21/2006 2:37 AM
Sheesh, must have been absent that day. :o
Good job hot rod, very succinct post. smile
Stu--pid
#97276 09/21/2006 9:39 PM
Thanks so much for all the help. I will rewire this weekend. If I get stuck Larry I will give you a call. This site is so great.
Kim
#97277 09/21/2006 10:24 PM
61apache,
I have a thought...it might be wrong, but I'll mention it anyway.
With your old externally regulated system, #4 on the regulator should have been the feed from the key and charge indicator light, if you had one.
If you hooked your new #1 wire to this wire, you wouldn't have to dig under the dash, plus you would have the idiot light function as before.
This light would offer the resistance necessary to stop any run-on.
Your old alternator should have had a large power lead that could just be connected to the new alternator.
Your sensing wire...#2 could wrap around as hot rod indicated and attach to the power lug.
Sure hope this is right!!
Stuart
#97278 09/22/2006 1:13 AM
Thanks Stuart, I was wondering If a good underhood connection point for the #1 wire existed. Thanks for your help.
#97279 09/24/2006 11:09 PM
Thanks guys, everything seems to have gone together without a hitch. grin
