9 members (walterhvogel, Jay R, DadsFirstPickup, moparguy, JW51, Jon G, Gray_Ghost, Stovebolt48, 1 invisible),
59
0
Mod | | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Help please... I put an SM420 Tranny on my 261 for my '59 half-ton truck and have the correct cover on the floorboard of the cab for the Shift Stick and Ebrake hand lever. I have a boot for the Shift Stick but can't seem to locate a vendor for a boot for the Ebrake lever. Can anyone point me to one? Many thanks! Jerry
edit: I realize this is a Big Bolt section, I just thought I could get my help better here, for a big bolt type tranny.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | So where did you find it? | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Classic Parts U.S.A. Boot Picture | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Hellomrwilson, Great! I have been looking for one of those. Thanks for the info. Wayne.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I looked again at my cover plate. My slot through the cover has full radius ends not rectangular. The boot I found above, is for a 47-55 1'st... I'm back to searching again! The Shift boot, I found at TruckAndCarshop in their 1947-1959 Catalog. BTW their prices are generally lower than most for the same aftermarket items. If anyone finds a source for the Ebrake Boot please hollar! Thanks! Jerry | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are you sure they had a "boot" on either shifter or brake lever? I know they had a thick foam sort of rubber donut between floor cover and transmission. I'm not an expert on the little details like that on these AD trucks but still don't think I've seen remnants of an original boot for either. The manual page isn't working at the moment but looking at the pictures in the shop manual is a good way to find out. http://chevy.oldcarmanualproject.com/Grigg | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | No sir, Mr. Grigg, I'm not sure of this at all and that is a very good AND interesting point. I have seen the foam seals for both Ebrake and Tranny and the round rubber boot that I have, might only enclose where the stick meets the SM420 tower! hmmmm
Thanks! Jerry | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I have the remnants of both boots on a 57 GMC Big Bolt with the sm420. They are torn and hard as a brick, but you can tell what they were originally. The e-brake is a rectangular hole, rounded at the ends, But I think I can cut the corners circular on the one he found on Classic Parts USA. I ordered it anyway. My original shifter boot was a big rectangular rubber boot with an aluminum plate. Gonna try one from Summit Racing or one of the round boots for a pickup.
