8 members (1955 1 Series, Steelonsteel, 55shaker, GRNHydra, 51sub, Wally / Montana, Peggy M, Hotrod Lincoln),
81
Mod | | | Forums66 Topics128,141 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Fellow bolters..... I have a 1950 3600 which is in the body shop. I purchased all new glass and seals from Jim Carter. I want to make sure the guy doing the body work does the glass installation correctly do I do not have any leaks. He mentioned he will use something that 'flows' to where any spaces might be. It's not a silicone or urethane or glue.
Anyway, can someone give me any tips or suggestions on what works? I'm sure he knows how to put the seals and glass in.
Thanks. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Your side glass needs no sealer, obviously. WIth new rubber your guy will probably use dish soap or canola oil to coax the fitted glass (no sealers in the channels) into their respective pinch welds on the body. My experience is that these usually fit VERY tightly when everything is new & will need no additional. If, after a water test, it is determined that further sealing is required then it could be applied carefully under the lips of the rubbers. Others may have different experience.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My thoughts are the same as squire's. No special sealer is needed unless leaks are present. If the side windows have metal frames around them, you will need setting tape between the frame and window, but this will seal it completely.
When I installed the back window in my 46 I didn't use any urethane, just soapy water, a plastic glass installation spoon, persistence, and patience. It doesn't leak either.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 3M bedding and glazing compound #08509, doesn't harden, excess wipes off. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Must be nice not to have to worry about a vent window. Everybody spends a lot of money doing a "one piece window" on newer trucks when Chevy had been there, done that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks for all the replies. I believe he is using something that does not harden that flows to find any openings. I'll ask him what it is. I'll be it the bedding stuff mentioned above. I believe he knows what he's doing, however I'm following the old adage.. TRUST every, but VERIFY!
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | David,the guys seem to have all the bases covered,the main complaint I hear about AD trucks is the front windshield seal,it's unlikely you'll need any sealant in the rear cab glass.
The main problem seems to be getting accurately cut glass. The seal requires the glass size to be correct to 'push' it out to correspond with the aperature. I can't vouch for Jim Carters glass but like the guys have already mentioned I would fit the glass 'dry' and then water test it,you'll soon find out if it needs any additional help! Most likely offenders will be the lower windshield radii. As 64fleetside already mentions 3M do a non setting glazing sealant specifically for this purpose and while it doesn't exactly flow,you can apply it once the glass is in should it be required and unlike some silicon products,wont hurt your paint 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I always attach windshield rubber to the windshield and keep it in a hot place for a long time to "train" the rubber to the glass. The rubber has been "trained" to be rolled up in a bag for a long time, maybe in hot places. But I've only done TF's , so far. And only Steele Rubber, which has not been in a big hot metal cargo container for a month with 900 pounds of other stuff on top of it.
