2 members (Rusty Heaps, PAUL Berardi), 141 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#971321 09/12/2013 11:59 PM
anybody know what the tool is called for installing the small rubber bead into the rear glass rubber ? and where can I buy one ? This is on the 55-59 chevy big back glass. THANKS
OLTrucks
Unregistered
OLTrucks
Unregistered
They are often referred to as a lock strip tool. your local auto parts store "should" stock them. here is a link to sears this is the one in my toolbox.
I may be off, but if I remember correctly, I think Pete told me
he just uses an old tooth brush ground down and he's done a few
of them.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks. I've never seen one. I have one on order.
Is there a trick to make the installation easy ?
OLTrucks
Unregistered
OLTrucks
Unregistered
Not really I use water based lube and just take my time. that tool should come with four different sized tips find the one that works best in the groove it should have plenty of room for the lock strip a warm gasket helps just be careful not to tear or gouge it.
hotshoe,I realise this is on an 'old fashioned' AD truck,but the technique is exactly the same....
Rear window and lock strip install.
More pix on Flickr.
Moderated by  MNSmith
