| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | anybody know what the tool is called for installing the small rubber bead into the rear glass rubber ? and where can I buy one ? This is on the 55-59 chevy big back glass. THANKS | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | They are often referred to as a lock strip tool. your local auto parts store "should" stock them. here is a link to sears this is the one in my toolbox. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I may be off, but if I remember correctly, I think Pete told me he just uses an old tooth brush ground down and he's done a few of them.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | Thanks. I've never seen one. I have one on order. Is there a trick to make the installation easy ? | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Is there a trick to make the installation easy ? Not really I use water based lube and just take my time. that tool should come with four different sized tips find the one that works best in the groove it should have plenty of room for the lock strip a warm gasket helps just be careful not to tear or gouge it. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks. I've never seen one. I have one on order. Is there a trick to make the installation easy ? hotshoe,I realise this is on an 'old fashioned' AD truck,but the technique is exactly the same.... Rear window and lock strip install. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
