0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 31 | Has anyone used a hydraulic throwout bearing on a T-5 tranny? Where did you get it from? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I researched the idea and talked to a few folks. It was not recommended. If it leaks then you get fluid all over the clutch and failure rate is an issue too. Let's see what other folks think. | | | | | Joined: Apr 2007 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 31 | I'm really limited on my room. I'm using a set of under floor pedals from ECI with a hydraulic clutch master. Would be nice to use a hydraulic throwout with it. It's going in my '37 GMC behind a 261 chevy. | | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | Unless a trans comes with intrnal slave or hyd. Release brg you cant just put one in.pressure plates fingers are different.best you can do is adapt a external slave onto the outside of trans.another thot is to use a cable | | | | | Joined: Sep 2010 Posts: 1,719 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,719 | Modern Driveline makes a hydraulic set-up for the t5. click Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | Good to know looks like a good part | | |
