3 members (moparguy, GMCJammer51, carbking), 118 guests, and 4 robots.
Topics128,285
Posts1,058,278
Members48,483
Has anyone used a hydraulic throwout bearing on a T-5 tranny?
Where did you get it from?
I researched the idea and talked to a few folks. It was not recommended. If it leaks then you get fluid all over the clutch and failure rate is an issue too. Let's see what other folks think.
I'm really limited on my room. I'm using a set of under floor pedals from ECI with a hydraulic clutch master. Would be nice to use a hydraulic throwout with it. It's going in my '37 GMC behind a 261 chevy.
Q
Q Offline
Unless a trans comes with intrnal slave or hyd. Release brg you cant just put one in.pressure plates fingers are different.best you can do is adapt a external slave onto the outside of trans.another thot is to use a cable
back yard wrench turner
Modern Driveline makes a hydraulic set-up for the t5.
click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Q
Q Offline
Good to know looks like a good part
