1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | i had my 66 F*** mustang towed the other day, it would run just fine then cut out. when it stopped it would start right up again...but my problem it when the tow truck dropped off my car the reverse no longer worked.. i mean all the drives and park but no reverse.......ANY CLUE you think it is linkage broken or deeper than that | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Did he tow it forward or backwards?
54 3100 with 235 62 flatbed dump C60 with 261
#9713 03/25/2003 11:53 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You are on the wrong board. Try putting F*^% in your favorite search engine. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If it was towed with the rear wheels on the ground for a long distance and higher speeds with the driveshaft still attached,it might caused some damage. The C-4 trans it has does not have a rear pump like my old galaxie and older GMs did. This is the wrong place to ask a question on a non chevy but since I also have that brand I will respond. | | |
