5 members (Ponchogl, gswbbc, Robert Crandall, Opelika Tom, 1 invisible), 88 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#9711 03/25/2003 9:17 PM
i had my 66 F*** mustang towed the other day, it would run just fine then cut out. when it stopped it would start right up again...but my problem it when the tow truck dropped off my car the reverse no longer worked.. i mean all the drives and park but no reverse.......ANY CLUE
you think it is linkage broken or deeper than that
#9712 03/25/2003 9:34 PM
Did he tow it forward or backwards?
54 3100 with 235
62 flatbed dump C60 with 261
#9713 03/25/2003 11:53 PM
You are on the wrong board. Try putting F*^% in your favorite search engine.
#9714 03/26/2003 1:20 AM
If it was towed with the rear wheels on the ground for a long distance and higher speeds with the driveshaft still attached,it might caused some damage. The C-4 trans it has does not have a rear pump like my old galaxie and older GMs did. This is the wrong place to ask a question on a non chevy but since I also have that brand I will respond.
