0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 10 New Guy | | New Guy Joined: Aug 2013 Posts: 10 | I just purchased a Wayne bodied 1950 30' school bus with 6700 on the hood. The tire size is a 7.50-20 if that helps? Is it a 1 ton, 1.5 ton, or a 2 ton...how do you tell? Also wondering what engine it originally had with what tranny? I could really use a manual....is there a link to anything on line? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | decided to keep it?  good resource for that type of info is the GM 'restoration pack', the 6700 series was a 2T - you'll find the 48-51 shop manual hereBill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | That 6700 series Bus is a 2 ton. Would have originally had a Loadmaster 235 6 cylinder engine. | | |
