0 members (),
80
0
Mod | | | Forums66 Topics128,050 Posts1,055,644 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97019 09/06/2006 3:38 PM | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I'm installing a 3 wire gm alternator in my stock 59 chevy truck and need some help with the wiring. Using the plastic two wire plug(red/white) I ran the the red wire to the bat side of the alternator and I ran another lead from the battery side of the alt to the top of the original voltage regulator after disconnecting the remaining wires from the regulator. My question is what to do with the white wire? Any help would be great | | |
#97020 09/06/2006 3:54 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | The white wire is the "signal" wire.Run that to the ignition switch so that it has 12 volts to it when the engine is running.The red wire can bridge over to the output lead(terminal marked BATT on alt).Run a 10 gage wire directly to the positive side of the battery.That's your charge line.I put a piece of 14 gage fusible link wire at the alternator termination for saftey sake.You might have to put a diode in line(on white wire)if the engine doesn't shut off when you turn the key off.Hope this helps!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#97021 09/06/2006 4:08 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jw4413,
Does your '59 have a idiot light in the dash? If you want to retain this light, it would serve as the 'diode', or resistance in your excite/white wire to prevent run-on. Someone should have an exact diagram for this lash-up..
Stuart | | |
#97022 09/23/2006 12:41 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002032#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001849#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001617#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
