| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I have a 3100 1955 1st. will m16/8 rims work???? If so what size tires???? thanks
" STUCK IN THE '50'S "
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | the rims I'm looking at =bolt p. 6x5.5 offset 12 cackspacing 4.97 hub bore 107.95
thanks
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Bolt pattern is correct, but the offset and back spacing are wrong. Judging from the specs you're giving, those wheels are for an '88-'98 K1500/K2500 light duty 4x4, or a '99-'14 1/2 ton. They might also fit on a Colorado/Canyon.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Thanks I will Pass..they are American Racing Diamond back... I think I'm needing 215/75/16 .......on a 16-7 .or 16-6... whats your thoughts..... Thanks again...
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Just wondering if I used 1/2 " spacers or even 3/4 do you think I could use these wheels ????
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You would need something more along the line of a 1 1/2"-2" spacer to allow for proper clearance. For tires, with them being an 8" wheel, you'll want to go with at least a 225/75/16.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Cool, do you think this would look right ????
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Well I bought them ,pick them up in the morning. I'm about 6 mos. away before I put them on..Hope they look as good as I think they will. Now I can sell the orig . 16 " rims....
