7 members (Rusty Heaps, mason86, Peggy M, wilbur53, ndkid275, Otto Skorzeny, 1 invisible), 115 guests, and 0 robots.
Topics128,050
Posts1,055,676
#970168 09/08/2013 3:53 PM
I have a 3100 1955 1st. will m16/8 rims work???? If so what size tires???? thanks
" STUCK IN THE '50'S "
the rims I'm looking at =bolt p. 6x5.5
offset 12
cackspacing 4.97
hub bore 107.95
thanks
Bolt pattern is correct, but the offset and back spacing are wrong. Judging from the specs you're giving, those wheels are for an '88-'98 K1500/K2500 light duty 4x4, or a '99-'14 1/2 ton. They might also fit on a Colorado/Canyon.
Bill Burmeister
Thanks I will Pass..they are American Racing Diamond back...
I think I'm needing 215/75/16 .......on a 16-7 .or 16-6...
whats your thoughts..... Thanks again...
Just wondering if I used 1/2 " spacers or even 3/4 do you think I could use these wheels ????
You would need something more along the line of a 1 1/2"-2" spacer to allow for proper clearance. For tires, with them being an 8" wheel, you'll want to go with at least a 225/75/16.
Bill Burmeister
Cool, do you think this would look right ????
Well I bought them ,pick them up in the morning. I'm about 6 mos. away before I put them on..Hope they look as good as I think they will. Now I can sell the orig . 16 " rims....
