5 members (Otto Skorzeny, Jay R, TooMany2count, Eisenholtz, Shardean), 59 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#969120 09/03/2013 11:04 PM
Hello-
I am in the process of doing some body work on a 46' Chevrolet 1/2 ton. The part I am trying to describe is the cab corner located behind the rear of the front fenders on each side. They are both pretty rotten on my vehicle.
My question is what is that sheet metal part called and does anyone fabricate a patch panel for those corners. Thank you.
Jim-
Jim,
Is this the cab corner you are looking for?
http://www.ebay.com/itm/Passenger-C...ries&hash=item35cae91b87&vxp=mtr
Also chech out these sites.
https://www.google.com/search?sourc...1.0...0.0...1ac.1.12.igoogle.3rHuKZSEjEc
I found my panels on Ebay.
Good luck,
Harold
Harold
if you are talking about the lower sheetmetal between the door and firewall it is a lower cowl pannel
Harold thanks for your help, but I think the cab corner you referred me to is for the rear cab corner.
I wish I knew how to submit a photo to describe the location of my rot. The best I can do is, if you removed the front fender and exposed the front cab corner that is where the rust has eaten that corner panel away. Thanks anyway for your help, I'll probably need to have it fabricated on site.
Jim-
Is this what you are looking for?
http://www.oldchevytrucks.com/cart/product.asp?prodid=SM456L&i=9883|||||
I installed a pair of these when the cab was off as it was much easier to cut and fit the patch panels into place. There are other sources for this repair panel.
Lots more pictures
