3 members (tclederman, UtahYork, 1 invisible),
105
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Hello- I am in the process of doing some body work on a 46' Chevrolet 1/2 ton. The part I am trying to describe is the cab corner located behind the rear of the front fenders on each side. They are both pretty rotten on my vehicle. My question is what is that sheet metal part called and does anyone fabricate a patch panel for those corners. Thank you. Jim- | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | if you are talking about the lower sheetmetal between the door and firewall it is a lower cowl pannel | | | | | Joined: Sep 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 57 | Harold thanks for your help, but I think the cab corner you referred me to is for the rear cab corner. I wish I knew how to submit a photo to describe the location of my rot. The best I can do is, if you removed the front fender and exposed the front cab corner that is where the rust has eaten that corner panel away. Thanks anyway for your help, I'll probably need to have it fabricated on site. Jim- | | | | | Joined: Nov 2011 Posts: 1,610 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,610 | Is this what you are looking for?
http://www.oldchevytrucks.com/cart/product.asp?prodid=SM456L&i=9883|||||
I installed a pair of these when the cab was off as it was much easier to cut and fit the patch panels into place. There are other sources for this repair panel. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
