2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#969822 09/06/2013 7:19 PM
Sorry but I'm confused again. The shop manual for a 55 235 and my Motors manual for late 50's pass car shows the rocker numbers to be 3,4,7,8 but mine are 5,6,7,8. The master parts manual 29-57 shows 5,6,7,8 with a revision as of Nov 57.Does 5,6,7,8 sound right? Also one of the #6 has a much smaller hole on top. Should I drill it out the same as the others? Also I assume the left-right thing is looking from the manifold side?
Thanks again.
Chev changed numbers and vent hole size and position a number of times. I would not worry about that.
There are left and right intake and exhaust rockers.
Here is a pic of how they are laid out.
My Blog
Anyone know of appropriate range of years for donor engine with rocker arms correct for a 53 235 /powerglide? Mine are scored beyond repair. I have come across a lot of weird differences in this engine compared to those manufactured before and after 1953. It appears to be a transitional (bastard) engine.
cassie #969878 09/06/2013 11:11 PM
The rockers interchange for 235's from 1950-58, although 1959-62 can be used.
My Blog
cassie #969927 09/07/2013 10:11 AM
That is what I half suspected after my research. Thanks for confirming.
