1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#96949 09/01/2006 12:36 AM
The previous owner snipped all the ignition wires for some unknown reason... On the box behind the dash, there are several male spade connectors. I need to know if the wires had female spade type plugs on them and which color goes where. I have a manual on order, but it's on backorder. Thanks in advance!!
Dano
my truck gets better every day...every PAYDAY smile
MrDanB,
Here is a link to the old Chev wiring page...maybe it will do until your manual arrives.
http://chevy.tocmp.com/chevywiring/
Stuart
Thanks for the help Stuart!!
Dano smile
MrDanB,
I must apologize. I read your profile and thought you had a '42 pickup, when in reality that is your cylinder index, (whatever that is).
After checking your previous posts, it appears you have a '57 pickup.
The page I linked does not have a diagram for that year, so it looks like I wasn't much help.
I know I have seen diagrams for your year truck...red58 probably has one for sure.
I will take my Prozac now and hope someone with some solid info pops in to save the day! eek
Stuart
I noticed that it didn't have info for 57 trucks after I went to the page and read it grin no biggie, at least you tried to help! BTW, a cylinder index is simply adding up all the pistons you have in your household. i.e. lawn mower, weedwacker, cars, trucks, etc. Then the goal is to have a cylinder index that is close to your age cool Thanks again for the help attempt...
Dan
I've got a good diagram for the wiring on a 58 Chevy, but I don't know what if any differences there might be. If you like, I could send it to you. Sorry, I can't remember where I got it, but it is definitely easier on my eyes than the one in the shop manual. Probably because it's an electronic copy that I can print out as big as I need it to be.
58 Fleetside, 235, "The Old Buckin' Bronco"
MrDan, the wiring info in the online 55-2nd manual should do ya
woohoo! You guys rock!! Thanks so much for the info. Have a great weekend....
DanB
