| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96949 09/01/2006 12:36 AM | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | The previous owner snipped all the ignition wires for some unknown reason... On the box behind the dash, there are several male spade connectors. I need to know if the wires had female spade type plugs on them and which color goes where. I have a manual on order, but it's on backorder. Thanks in advance!! Dano
my truck gets better every day...every PAYDAY | | |
#96950 09/01/2006 12:55 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | MrDanB, Here is a link to the old Chev wiring page...maybe it will do until your manual arrives. http://chevy.tocmp.com/chevywiring/ Stuart | | |
#96951 09/01/2006 4:15 AM | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | Thanks for the help Stuart!! Dano
#96952 09/01/2006 5:01 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | MrDanB, I must apologize. I read your profile and thought you had a '42 pickup, when in reality that is your cylinder index, (whatever that is). After checking your previous posts, it appears you have a '57 pickup. The page I linked does not have a diagram for that year, so it looks like I wasn't much help. I know I have seen diagrams for your year truck...red58 probably has one for sure. I will take my Prozac now and hope someone with some solid info pops in to save the day! Stuart | | |
#96953 09/02/2006 12:20 AM | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | I noticed that it didn't have info for 57 trucks after I went to the page and read it  no biggie, at least you tried to help! BTW, a cylinder index is simply adding up all the pistons you have in your household. i.e. lawn mower, weedwacker, cars, trucks, etc. Then the goal is to have a cylinder index that is close to your age  Thanks again for the help attempt... Dan
#96954 09/02/2006 7:50 AM | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I've got a good diagram for the wiring on a 58 Chevy, but I don't know what if any differences there might be. If you like, I could send it to you. Sorry, I can't remember where I got it, but it is definitely easier on my eyes than the one in the shop manual. Probably because it's an electronic copy that I can print out as big as I need it to be.
58 Fleetside, 235, "The Old Buckin' Bronco"
#96955 09/02/2006 1:55 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | MrDan, the wiring info in the online 55-2nd manual should do ya Bill | | |
#96956 09/02/2006 11:10 PM | Joined: Feb 2006 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 117 | woohoo! You guys rock!! Thanks so much for the info. Have a great weekend.... DanB
