7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby), 114 guests, and 3 robots.
Topics128,129
Posts1,056,362
Members48,441
#969124 09/03/2013 11:22 PM
After rebuilding the 2 speed rear axle (Tinkum model 5800 - M - 429)(last number hard to read)I need some shims for the ring gear (intermediate) shaft. They are not interchangeable side to side.
Does anyone know where I can get some?
I know this is a drive train subject but it is a Big Bolt specific item. I will post there as well.
3B Offline
Hy Jim Sears, I believe that rear axle brand is spelled Timken. Call a shop in your area that rebuilds large truck transmissions/differentials, explain what your looking for, they may be able to help you track down the parts you need. Is that a Timken double reduction diff.?
Yes, typo. It is a double reduction.
Checking local heavy shops is a good idea.
The local truck heavy truck shops seem to think it is extinct.
Manufactured some shims to finish the assembly.
they're right frown
