| | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | After rebuilding the 2 speed rear axle (Tinkum model 5800 - M - 429)(last number hard to read)I need some shims for the ring gear (intermediate) shaft. They are not interchangeable side to side.
Does anyone know where I can get some?
I know this is a drive train subject but it is a Big Bolt specific item. I will post there as well. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jim Sears, I believe that rear axle brand is spelled Timken. Call a shop in your area that rebuilds large truck transmissions/differentials, explain what your looking for, they may be able to help you track down the parts you need. Is that a Timken double reduction diff.? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Yes, typo. It is a double reduction.
Checking local heavy shops is a good idea. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The local truck heavy truck shops seem to think it is extinct.
Manufactured some shims to finish the assembly.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | The local truck heavy truck shops seem to think it is extinct. they're right  | | |
