4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#96896 08/29/2006 9:29 PM
I though it would be a good idea to stick a third brake light low in the rear window of my '49 1/2T pu. I got what looks like a pretty good light from J.C. Whitney, and the Whitney catalog recommended adding a logic circuit it sold so the 3d light didn't blink every time I braked and signaled a turn.
Wiring the logic circuit was easy -- one wire to left stop light, one to right, the last to the 3d light.
I've got the 3d light grounded to the frame, but the light comes with loony pictures (no diagrams) and instructions just about translated from Chinese. So where does the 3d light get its power? From the brakelight switch ahead of the flasher? If it does, why all this business with the logic circuit?
Never start vast projects with half vast ideas.
#96897 08/29/2006 10:04 PM
Retread,
Good question. If you powered the light AFTER the brake light switch, but BEFORE and turn signal switching, it seems you could do without the logic circuit.
My bet is that the logic circuit was designed for new rigs where you couldn't access the brake circuit as easily before it gets confused in the turn signal spaghetti.
What would happen if you dumped the logic circuit, grounded the light and powered it from the switched side of the brake switch...it should light up on every brake application it seems to me!
Stuart
#96898 08/29/2006 10:14 PM
Riding in the Passing Lane
I put one on my 70 & wired it directly to the stop light switch. Works fine. I believe all the other setups are for cars were you come off the back lights & it uses diods to prevent the light from flashing. I did put a fuse in the wire so if it shorted out it would not interfear with the other circuits.
1972 Chevy c10 Cheyenne Super
#96899 08/29/2006 10:34 PM
Sorry you lost me when you used the term pretty good part and JC Whitney in the same sentance.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#96900 08/29/2006 10:54 PM
True, but interjected in that 'sentance' was the give away word we all dread...CHINA!
Stuart
#96901 08/29/2006 11:48 PM
i just used a red clearance lamp (double filiment) from 'flaps' and it works great, @ only $3.00 in my neighborhood.
i wired the two filaments together and connected that one wire to the brake lamp wire & drilled two holes. this clearance lamp grounds thru the mounting bolts to the chassis.
done in 1/2 hour.
Jim & Caroline
#96902 08/29/2006 11:59 PM
Okay. Thanks to all. Direct from the brake light is how I saw it. I'll give that a try then look into the dual filament fix. And, well yeah, I thought, how can JCW foul up a simple thing like a light. You have to see those instructions.
