1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96888 08/29/2006 3:57 PM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | I spent Saturday tracking down an electrical gremlin on my truck. The taillights were not working, and I finally traced the problem to the fact that the bed on my truck does not appear to be grounded. (?) If I grounded the taillight mount brackets to the bumper using a test lead, the lights would come on. I re-wired the two taillights and the license plate lamp, as well as removing the brackets and cleaning their connection to the body to ensure proper ground. I'm getting a solid 13 volts to the hot side of the connector. Despite all of this, I could not get the lights / signals to work until I ran a ground wire from the bed to the frame. It appears as if the bed is in contact with the frame in multiple places, so any ideas of why I saw the odd behavior? Thanks!
1961 Chevrolet K10
#96889 08/29/2006 5:54 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My bed is pretty rusty and the grounds weren't real hot. The brake light barely worked, and the blinkers you could only see if it was REALLY dark. I ended up going to NAPA and picking up one of those sealed plastic terminal boxes and running all of the grounds to that and exporting two ground wires to the headlight ground screws.
Works like a dream.
You should be able to run ground wires to any spot on the frame, though. You don't have to run the grounds all the way up to the front of the truck. The only reason I did it that way was because I knew that those grounds were good. | | |
#96890 08/29/2006 6:05 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not odd behavior at all Troy, quite normal on an old truck, for the same reason you cleaned up the lights and their immediate mounting, you need to tend to the rest of the circuit - the bed 'sitting' on the frame is a real poor ground ... even where the bolts go thru is poor after a few years of slow galvanic corrosion building up - may look ok, but electricity ain't fooled
it's always a good idea to have a wire, well connected to cleaned spots, between the bed and the frame - same for the cab and the frame - as Brendan sez, the ground is critical to the proper flow of things
Bill | | |
#96891 08/29/2006 7:52 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I am trying to locate a good spot to ground my bed to the frame. Where do you guys think is the best spot? In other words, what bolt on the bed is a good bolt to ground from to the frame? May I ask the same for the cab? What bolt on the cab is a good bolt to run a ground strap from the cab to the frame? The engine seems to be a little easier to find a bolt on. I like the bottom bolt that holds the starter on the engine. It's down under and not so noticeable. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#96892 08/29/2006 9:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | on later trucks the factory put a ground strap [the flat braided type] from a starter bolt to a threaded hole on the toeboard part of the floor, like such, red X - for the bed I added a heavy wire from the frame to a hole I drilled on the back cross-sill, which is well bolted to the bed sides - use a good toothed star washer under both ends of it to dig in to the metal, same as the factory did on that cab ground - the frame will usually get a good ground from cab mounts, but it doesn't hurt to add one from a starter bolt | | |
#96893 08/29/2006 9:19 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Red58 --
How heavy a ground wire did you use, 10-gauge or so?
Never start vast projects with half vast ideas.
#96894 08/29/2006 9:22 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's plenty, even 12 or 14, and I use soldered on ends, not crimps - the current is minor for lights, doesn't take much if contact is good
Bill | | |
#96895 08/30/2006 6:08 AM | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | Thanks for the info. On closer inspection the bolts that hold the bed to the frame are loose and the bed does appear to just be resting on the frame, which is no good for consistent grounding. I ran a 12 gauge wire with tinned ends / connectors from the area under the tailgate to the frame just underneath and this is working fine. I'll fix the bed issue when it comes off for restoration. The PO welded a metal plate over the existing bed wood and I need to figure out a clean way to get that out before I can easily remove the bed.
1961 Chevrolet K10
