4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#968667 09/02/2013 2:54 PM
how do I determine the correct flywheel for a 6 volt vs 12 volt. I want to keep the 6 volt foot starter and I have several flywheels to choose from. I am putting in a 235 motor in my 52 1/2ton pickup and switching to 12 volt but the 6 volt starters turn the motor over much faster
Paul
1 Offline
You have to use a 12V starter with a 12V flywheel, you cant mix and match a 6V with a 12V starter or flywheel.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
yes I know. i want to use 6 volt starter, so i need to know which flywheel goes with it. I think one has more teeth than the other just not sure which one
thats what i needed thanks.
