| | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | how do I determine the correct flywheel for a 6 volt vs 12 volt. I want to keep the 6 volt foot starter and I have several flywheels to choose from. I am putting in a 235 motor in my 52 1/2ton pickup and switching to 12 volt but the 6 volt starters turn the motor over much faster Paul | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | You have to use a 12V starter with a 12V flywheel, you cant mix and match a 6V with a 12V starter or flywheel.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | yes I know. i want to use 6 volt starter, so i need to know which flywheel goes with it. I think one has more teeth than the other just not sure which one | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | thats what i needed thanks. | | |
