4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#968308 08/31/2013 8:42 PM
Bondo Artiste
Bondo Artiste
I have a new re-pop stock style gas tank from Jim Carter. Looking for advice on the best fuel tanking sending unit. Where did you get yours? This is for my 1950 gmc suburban.
Thanks in advance.
~ Phillip
Phillip
The sending unit will need to be matched with the fuel gauge you are using. There are a couple different electrical values ( ohm readings) that the sending unit sends to gauge to show correct fuel level. Once you determine what the gauge requires go back to carter and asks suggestions as they should know what sending units fit in the tank they sold you. Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
