| | | Forums66 Topics128,087 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Can any one tell me if the steering gear boxes for the Big Bolts are the same as the ones for the smaller trucks?
Glory Bound...
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rautru, the answer is no they are not the same, the 4000 series and 6000 series use the same box, hope that helps. | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | It does help. That rules out the ones for sale at LMC Truck then.
Glory Bound...
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Rautru I have sent you a PM. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Are they the same boxes from a 1948 6400? | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I am not sure. Can anyone answer that for us?
Glory Bound...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I guess you could answer that question with a parts manual, but since I don't have one, that is why I posted the question.
Glory Bound...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | And that's why I gave you the link to the parts manual above. | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | My bad, I did not notice the link to the manual.
Glory Bound...
| | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Well, I couldn't find anything in the parts manual relates to manual steering gear boxes.
Glory Bound...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you're not looking in the right place, the "box" is not seperate from the column/shaft, and further on you'll find the shaft/worm are different for series 3 and series 4/6 ... probably length Bill | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | The answer to that question is no they are not the same. The change happened mid year 1955 with the advent of the taskforce series trucks. | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 |
Glory Bound...
