1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I have a new re-pop stock style gas tank from Jim Carter. Looking for advice on the best fuel tanking sending unit. Where did you get yours? This is for my 1950 gmc suburban.
Thanks in advance.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Phillip The sending unit will need to be matched with the fuel gauge you are using. There are a couple different electrical values ( ohm readings) that the sending unit sends to gauge to show correct fuel level. Once you determine what the gauge requires go back to carter and asks suggestions as they should know what sending units fit in the tank they sold you. Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
