2 members (VicZ, doyle1950),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | I just got some new oil filter lines from American Classic. The tubes themselves have brass fittings on the ends, but the bottom ends also have steel swivel-type connector fitting. When I went to thread the steel fitting into the brass T fitting at the engine block (this T fitting also connects the oil gauge tube), the threads in the T fitting started to strip.
I checked all of the fitting threads with a caliper. It's kind of hard to tell since the thread length is only about 3/8", but I believe the new hoses have taped threads (there's about a 0.010 inch difference from one end of the thread to the other).
I checked the old hoses and the T fitting, and they seems to be straight thread. Most of what I've read on this forum seems to talk about tapered threads though. If I have to replace the T fitting (which I'm guessing I do), I want to make sure I get the right fitting.
Last thing I want to do is to mess up the threads in the engine block. I guess that may be unlikely, since the brass fitting would strip before the block threads, but I still don't want to take any chances.
Does anyone know if the T fitting for the block should be tapered or straight threads? Any other insight on these hoses and fittings?
Thanks for any info.
| | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Just a quick update. After further checking, the male fitting on the T (the end that threads into the block) seems to have tapered threads. It just seems kind of strange that the male threads on the T would be tapered, and the female threads (where the hose connects) would not be tapered. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the Tee will be an add on item, not original, so you'll need to find a 'correct' one to mate to the other fittings, should be able find it at an auto parts or plumbing store
Bill | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Rather than a new T fitting maybe an adapter to fit the end of the hose, tapered to straight thread?
Ed
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Not to hijack the thread... but I'm getting ready to put an oil filter on too, anyone have a part number for the 'T' fitting? | | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Thanks Forty9. That came to mind too, and seems to be the easiest fix as long as I can find such a fitting. I'll shop around tomorrow, and if I can't find anything locally, will look online. I just need to figure out what the thread sizes are. Thanks again. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If you have 1/8 pipe threads here is an option ...link... You can find the same at your local auto parts. | | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Thanks gents. I stopped by the local Ace Hardware store today, and picked up some fittings. Their selection was a little limited, so I had to get a couple of fittings for each connection to make it work. It pretty much doubles the number of threaded connections, so I'm keeping my fingers crossed that it doesn't leak. I won't know for a little while, since I have some other work to get done before I connect everything back up. Hoping for the best! | | |
