0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Do they go to the inside or outside of the frame? Mine were riveted in the middle, sandwiched around the frame and bolted on as in the picture below, which doesn't seem correct. ...or is it? http://farm6.staticflickr.com/5179/5548587334_31bdb39fa5_z.jpg | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Mine were on the outside of the frame, just bolts, no rivets (if I remember correctly), I can look when I get home though | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | GMJager - The rivets hold the two parts of each bracket together, the bolts were what was holding it to the frame.
Brad Allen - THANKS! What type bolts did you use? I was thing Grade 8. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Outside here to, but it's a 3600 and the two pieces are factory riveted together on all the bumper brackets that I've seen, front, rear for all years.
It's only a matter of a few cents, but no need for grade 8 bolts, this isn't a highly stressed area unless you're hanging a trailer hitch from it. Grade 5 or even a grade 2 bolt would be adequate.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | So what about using stainless bolts and getting hit from the rear?
...says the guy who has had no rear bumper for a couple years. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think I used grade 5 just because I had some available. I will give you this advice, when you mount the bumper leave everything loose until you get all the holes made, then tighten! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ya want to spend the moolah for stainless, go right ahead, least they won't stain the bumper bracket after they've been in place for 62 years like the original plain steel ones did. Some guys re-assemble their whole truck with SS. If'n ya get hit from the rear year bumper is gonna fold up long before even the cheapest pair of 1/2" bolts will shear, (bout 18,000 lb. to shear both grade 2's). Might ad to Brad's advice that you also may need to adjust the brackets to line up with the holes in the bumper. I use a big old Crescent wrench (18") to re-bend the brackets.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | What is the difference between front and rear brackets? I bought a pair that were hand labeled rear but I think they are front. It doesn't really matter except for just to know. They worked for me.
Also, about how far below the bottom of the tailgate should the top of the bumper be?
I finally got around to putting the rear bumper on my truck but I think it hangs too low rendering my tow hitch inoperable. I can take it back off and flip sides which will raise the bumper significantly but, (will it look "stoopid"). | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Denny - I have a handful of the right size in stainless along with stainless washers, lock washers and nuts. I'll be powdercoating the brackets, simply because I have the extra black powder and the tools to do so, and eventually coating the frame with POR15 or similar so I'd hate to have a set of rusty bolts ugly up my purdy work. FriedGreenTmater - The rear brackets angle down in the middle. These are good examples of where it should sit. In the second one you can really see the angle in the bracket. http://farm8.staticflickr.com/7419/9219955748_4ca8434421_b.jpghttp://farm4.staticflickr.com/3824/9217203391_8b6c21fe35_b.jpg | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Great pics, nice truck, thanks.
Mine looks to be about the same relationship to the tailgate vertically. I guess I will have to figure some other way around the hitch problem. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | ....Some guys re-assemble their whole truck with SS..... You mean everyone doesn't????
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not us 95% purists John.
Nice pictures Eric, shows the dip in the rear brackets just perfectly. Need that for the tailgate clearance. Hope my '50 "Mariner Blue" 3/4-ton turns out looking half that goot. Like the shot with the corn in the background, perfect setting for one of these old Stovebolts. DG
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thought you might have finished it up over the summer. Anyway, that's still a nice looking truck and I'm full of envy.
Denny G
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Thanks Denny! At the rate I'm going, the finish line is another 10yrs away. Heh. Took me almost five hours tonight to get the dang bumper on. Bout 30min of that was cutting out the old rattling bed bolts and cross sills then the next four hours were spent playing hide n' seek with tools around the garage and wrestling with the bumper and brackets. ...and I figure at least a good 30min was spent just cussin' and starin' at it with my hands flappin' around. Good times.  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Remember, it's not the time, nor the money, but the task at hand that's the important factor in this endeavor. If your not havin' fun with it then ya need to think about another hobby.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Agreed 100%! Actually, I really am almost finished with it. My goal was to keep it on the road as long as I could while working on it and after about 2-2.5yrs I am just about at that point where I'm ready to do the body work - not this winter but maybe next. That means finally taking it off the road and pulling the cab. At that point I'll blast and coat the frame and start thinking about paint colors.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That sounds exactly like my plan, cept I've been enjoying driving it so much I'm going into my seventh winter of, gonna get the body work done this winter.
DG
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I'll probably do the same for a couple/few years. My frame is solid but rough to the touch and orange and my front cab support is disappearing around the mount. Right now I'm enjoying the heck outta it. Driving to meets, drive-ins, cruises, burger joints and occasionally the office. It's a sight in our office parking lot and it must look a bit strange to see me driving it in a suit. | | |
